Results 1 to 10 of 12
Thread: finally made a decision
    Apr 2005
    LUNATI
    Advertised Duration IN/EX: 283/283
    Duration @.050 IN/EX: 221/221
    Gross Valve Lift IN/EX: .558"/.558"
    Lobe Sep Angle / Intake Ctr Line: 114/110
    Valve Lash IN/EX: Hyd/Hyd
    RPM Range: 2500-6000
    says i need springs what ones do you reccomend.. ls6?
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    Apr 2005
    belton, tx
    comp 918&#39;s, worked for me and many others.
    2013 2wd Z71 6.2 crew cab
    Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
    best time 12.93 1/4 mi @ 103 in the turbo truck.
    1968 Camaro Convertible, super sweet!
    Apr 2005
    also whats the stock length on the 99 pushrods? the lunati pushrod specs are
    5/16 Dia. Overall Length 7.410" those are the specs on the lunati ones but if the stock ones are the same i dont need to spend the money then rihgt?
    Sep 2004
    Breaux Bridge, LA
    we have almost the same cam. i went with the 918&#39;s with manley harden pushrods (7.4") i&#39;ve haven&#39;t had a problem with them. spins up to 6700 with easy. no valvetrain noise either.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
    Apr 2005
    everyones tellin me its gonna suck down low hows yours treatin ya
    Jan 2005
    Conway, AR
    You will be fine down low, a stall would help, but i think you will be ok. You might wanna get some hardened pushrods, just to be on the safe side.
    Chris
    Sep 2004
    Breaux Bridge, LA
    mine runs awsome down low. pulls 1.75 60&#39;. that&#39;s with a 3000 stall though. i&#39;d say go with a trailblazer stall or something simillar around 2500 stall so that it can take full advantage of the cam.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    Knothead Racing
    Apr 2005
    yeah but its not gonna be like shitty without a stall though? everyones actin like im gonna not wanna drive it
    Sep 2004
    The Lunati cam and the TR220 cam like cajuns are nothing alike. The lunati cam is no where near as aggressive as the TR cam. I dont think its even comparable with the comp xe series cams. On that note, it will probably be a dog on the lowend unlike a more aggressive lobed cam is.
    Sep 2004
    Breaux Bridge, LA
    thanks for the info reaper. i was under the impression that they were similar. my fault...
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    Knothead Racing
