Results 1 to 2 of 2
Thread: BEP20 Token Generator - Create BEP20 Tokens Instantly with U
    Sep 2021
    Usa
    What is a reward token, exactly?
    A reward token rewards users for completing various tasks. The most prevalent instance of this type of activity is HODL, which rewards users for simply holding tokens. It operates by charging a fee on each transaction equal to a percentage of the tokens transferred.
    The tokens collected are then used to reward existing holders. To receive the rewards, you can use your token or another popular cryptocurrency, such as BUSD or DOGE.
    However, a much simpler method exists now that makes use of the incredible no-code platform Unicarve. Unicarve's BEP20 token generator enables you to create bsc token with modern tokenomics features such as reflection or rewards in BUSD or another token, liquidity generation, marketing and charity wallets, and hyperinflationary buyback. It not only enables the creation of tokens on Binance Smart Chain through the use of modern controls, but it is also extremely simple to use and one of the most affordable token generation platforms available.
    What types of reward tokens are available?
    The most frequently created reward tokens are reflection tokens. The collected tokens are distributed as a reward in this mechanism. Users accumulate additional tokens over time by simply HODLing the tokens. This is popular for a number of reasons.
    To begin, it is extremely effective because it makes use of a technique called reflection. To keep things simple, reflection does not require explicit distribution of reward tokens; rather, it updates the user's balance based on their current holdings, which saves a significant amount of transaction gas. Additionally, by distributing your own tokens, you avoid the need to sell them in order to acquire BUSD or other tokens, which can result in a decline in the value of your token.
    Feb 2024
    G’day, estaba juntando dinero para regalar algo caro a un familiar y no sabía cómo avanzar, así que una noche aburrida probé algo distinto. Al principio no tuve suerte y perdí varias partidas, pero en https://coolzinos.com.es decidí subir el riesgo en Sweet Bonanza y ahí fue cuando apareció un premio importante. Me llamó la atención que para jugadores de España haya bonos especiales que hacen todo más emocionante, así que lo dejo como recomendación personal.
