First swap 96 k2500
Hello all, i am about to start my first swap and am trying to get a few of the parts lined up. I also want to use this as a platform to ask questions i have along the way. I have been reading alot about other swaps and searching on alot of different forums. Thank you for the info you have provided and i hope that his goes smoothly
I have a '96 k2500 with the 5.7/4l80e combo. I have a complete donor '01 suburban 2500. My plan is to mate the 6.0 to the '96 4l80. I have read that i need to get the motor mounts that install the 6.0l back about 1". I found the dirty dingo mounts that say they allow 1/2" movment rearward. What are the other mounts that if i need to move the engine back that i need? Looking at the Trans-dapt 4575
Will the fuel pump from the "01 drop into the '96 tank? or has anyone swapped the entire tank from a nbs to obs?
Will HP tuners support deleting the anti-theft?
Ended up going with the transdapt 4575. Yanked the lq4 and 4l80e out today. Started working on the 96 but ran outta steam. Will try to finish the mechanical side of things tomorrow
Found away around the VATS too.
- You may not post replies
- You may not edit your posts
