			95 4l60e to any year 4l80e  4x4
					Have read alot of posts but maybe missing the one I really need..  I have a 95 xcsb with 4l60e. 2004 lq9 swap and psi stand alone harness. I want to be ready when the 60 goes out.   I have read about repinning harness but it's for newer 4l60 trans.  What 4l80e  should I transplant? What transfer case?  And what will be needed to make it work?  Cross member? Drivelines?     Psi wants me to remove harness and ecu and send both back for work. I want to have everything ready so I can do the work in the shortest time possible.
- You may not post replies
- You may not edit your posts
