My truck originally had a 4.3 with a DBC throttle body. I attempted to switch over to DBW when I did my swap and it was more headache than it was worth. To switch to DBC you would need a 99-02 PCM, wiring harness, DBC throttle body, pedal, and the bracket that bolts to the intake to hold the cable itself. Also you will need a new oil pressure sending unit with the older harness. acdelco part number: d1818a. A forum member, allblacksierra switched from dbc to dbw on a 4.3 to 5.3 swap if your'e interested in searching through some of his posts and continuing to do the conversion. My advice would be to stick with whichever drive by setup the truck came with from the factory. Hope this helps and good luck with the build.
2000 RCSB
LQ9
Torquer V2
T56 Magnum
305 drag radials
3/4 lowering kit
