Results 1 to 9 of 9
Thread: 1994 full size blazer to lq9
    Feb 2016
    So im going to swap a 2002 lq9 with a tick sns torquemax stage 1 cam into my 1994 full size 4wd blazer. Should i keep the 4l60e thats in there now? And if so what flex plate do i need. What trans should i use if no, that will bolt up to my tcase.
    Apr 2015
    New Hampshire
    you could use it, but you would be on borrowed time. I would look for a 4l80e.
    96 chevy k1500, 5.7l vortec, 4l60e, 14 bolt, volant CAI, pacesetter LTs, spintech 6000, b&m, 33's--awaiting lq4/4l80e swap
    94 z28 camaro m6, 383 LT1, slp CAI, pacesetter LTs w/ORY, e-cut out, spintech 2otl, hurst SS, strano sways, BMR suspension, viking coilovers, solomon tuned
    Feb 2016
    What about a 4l65e? I heard the 4l80e would make me have to buy new drive shafts for the front axle and rear.
    Apr 2015
    New Hampshire
    you shouldn't need new drive shafts if you are using the factory tcase from your truck
    Feb 2016
    But the 4l80e isnt the same dimension as 4l60e or 65 right?
    Sep 2012
    Sherwood, Arkansas
    That is correct, the 4l80 is longer and will require custom driveshafts.
    Apr 2015
    New Hampshire
    how much longer is it? I thought they were very close in size so I could keep my tcase in the stock location and use the adjustability in the swap motor mounts to take up the slack
    Sep 2012
    Sherwood, Arkansas
    Found this bit of helpful info just by searching. I am running 60e with dingo mounts and a 14bolt. My stock driveshaft will not fit even with the mounts slid all the way forward, but my build is completely different. Looks like ur just gonna have to test it out and see.
    Mar 2013
    Long Beach California
    i put the lq9 in mine with stock 60e. tranny was done in 3 months. but it did have 250k on it... built 80e now.... wont look back. but i did need to get shaft shortened a bit. but not a bad thing since the ujoints and bearings also had the same mileage, all that was replace and balanced too... so i spend a bit on that but hey, now i dont have to worry about a thing... just saying
    CALI LEGAL ENGINE SWAP!
