Results 1 to 3 of 3
Thread: Rained on my LS1
    Jul 2015
    Rained on my LS1
    My engine was sitting on a pallet outside on the driveway covered by a tarp when we left for a 9 day vacation. Apparently we had strong wind while I was gone and the tarp was blown loose exposing the engine to the rain. I had the engine ready to install with the intake, and exhaust manifolds off (rags stuffed in the ports to keep stuff out) as well as all the accessories. The coils were also exposed. It will probably take me at least a couple of more weeks to get this engine swapped in and ready to run. Should I do anything special to flush the water out of the engine and prevent rust?
    Sep 2015
    I would pull the plugs and spin it over to make sure there is no water in the cylinders. Also check the oil. If there is any water get it out right away!
    Jul 2015
    Quote Originally Posted by Frige View Post
    All the fluids were drained on it before the rain incident. I am thinking of filling it with cheap oil, pull the plugs, spin it over, and then drain the oil.
