Results 1 to 2 of 2
Thread: Neutral Safety Switch Bypass
Threaded View
    I am using an automatic truck harness in my manual truck and the neutral safety switch has been giving me problems and now I cant start my truck with the key. I tried hooking up the ignition positive voltage to the starter relay feed with no luck. However when the key is on and I tap the IGN wire to the yellow park/neutral output, the starter cranks but I can't leave it wired that way because the starter won't disengage. Does anybody have any experience with this or any ideas on how to get rid of the Neutral Safety Function completely? Thanks
    2000 RCSB
    LQ9
    Torquer V2
    T56 Magnum
    305 drag radials
    3/4 lowering kit
