Results 1 to 5 of 5
Thread: 5.3l/nv3500
Threaded View
    Jun 2015
    5.3l/nv3500
    Hey,
    I have done hours of research and know that they work together with a 4.8L fly wheel, 1377c release bearing, and 6302-vsp43 pilot bearing. All of which I have ordered and have on the way. What I have not come across is what people used for hardware. I believe I came across some ARP bolts that will mount the flywheel and another set for mounting the pressure plate. Can someone confirm this? My next question is on clutches. They say you can reuse the stock clutch but it sounds like you have to remove the dowels from the flywheel and ream out the pressure plate bolt holes to allow the metric thread bolts. Since I am in need of a clutch kit can I just order a 4.8L clutch kit and skip removing dowels and reaming holes? Will the 1377c release bearing work properly? I am swapping an 05 5.3L in with my stock 5 speed in a 91' c1500.
    Thanks!
