Any recommendations for a good serpentine belt that will handle a lot of power?
You can try the Gates Predator Powerband belts. Not sure about truck applications but it wouldn't hurt to call them. Markets/Applications
Predator belts are well suited as replacement belts for applications exposed to pulsating loads or heavy shock loads, such as mining, agriculture, wood processing, oil field equipment, heavy construction and sand/gravel operations.
