Results 1 to 10 of 13
Thread: L92 intake throttle cable bracket
    Oct 2014
    Assuming others have done this. Not sure where I can find a bracket for a cable throttle body for a 6.2 truck intake. Anyone have any advice or options? Throttle body is an edelbrock 90mm.
    Dec 2008
    South Carolina
    Iv been searching for the exact same thing....with no luck. If you find anything be sure to share!
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
    Oct 2014
    Will do for sure. So far it seems like the one from ws6 project for the car intake might be the best option with a little modifying to clear the evap hose
    Oklahoma
    I bought the cable bracket from ws6project and have it installed i just need to reroute pcv line, so far im pleased with it.
    Oct 2014
    What one did you buy? The one that bolts to the back of the tb? And what tb are you running?
    Dec 2008
    South Carolina
    chevyman94 will you post a pic?
    Oklahoma
    i bought the ls holley cable bracket its a 95mm part number 20-147, it bolts up in between the throttle body and the intake, and the gaskets are included. Website was
    ws6store, as far as the throttle body i just bought a 92mm ls2 4 bolt design off of ebay.
    Oct 2014
    there was no problem with the difference in size of the tbody compared to the flange piece? Seals all tight? Any pictures actually ?
    Oklahoma
    i didnt' find any issues when i was putting it together. after install i started it up and checked for leaks and i didnt' find any.
    Oct 2014
    That looks nice actually. Wonder if I would run into any issues on a 90mm tb. I don't think I would after seeing that one. Yours is only 2mm bigger. Thanks for the picture!
