Results 1 to 6 of 6
Thread: OBS With LQ4 & 411 PCM Gas Gauge Fix
    Sep 2009
    NE Ohio
    I cant find this anywhere. I am using HPTUNERS and have the setup in the title. I cant figure this out. I know it can be done with HPTuners.
    Anybody know how to fix this problem?
    Thanks in advance.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
    Mar 2013
    Long Beach California
    The old gauges use 0-12v signal straight through the float in the tank. The newer pcm requires 0-5v signal via newer style sending unit.... only way I could get around this to use old gauges and keep new pcm happy was to add the newer sending unit to the tank.
    So basically I have two floats in the tank. The original to control the gauge..And the newer style to feed signal to lsx pcm.
    Sep 2009
    NE Ohio
    I just put in a a whole new fuel pump module because mine went out and I dont feel like going through all that again to do what you mentioned. LOL
    Jun 2005
    Way up in North Dakota
    Thanks for the wiring-manual links.
    Sep 2009
    NE Ohio
    Quote Originally Posted by metalchips View Post
    Your welcome. If you need more, let me know. I may have more that I have on my computer that I need to look for.
    Nov 2013
    Fort Hood, TX (for now)
    Did you end up finding the remedy to this?
