O2 sensor and alternator variances?
So were all familiar with case grounded and isolated ground O2 sensors on the Gen3 stuff. It seems that any LS1B PCM will work with either style, provided that the O2s are wired correctly for the type of sensor being used???
Also, some are male connectors and some are female (upstream). What is the best way to determine which O2 sensors to use?
- You may not post replies
- You may not edit your posts
