Results 1 to 2 of 2
Thread: Strange high rpm miss
    Oct 2005
    I have a 5.3 T56 conversion in a 92 full size. The truck has had the engine transmission in its current state for a few years and has been 100% trouble free.
    Recently if I pull hard up to 5000 or so rpm then shift the truck feels like it hits a wall and has what seems to be a miss for a second or so then pulls out of it. When it revs back to 4500-5000 rpm then shift to third same thing.
    If I free rev the truck to 4000 or so then catch it at 2500-3000 rpm and hold the throttle there it will miss for a couple seconds then clean out.
    No weird sounds. It idles fine, pulls hard off idle all the way through the rpm range , just seems to hit a wall at the gear change.
    engine is stock with a cam and nelson tune. specifics are in sig.
    thanks in advance for any help
    Patrick
    '92 Fullsize, swb rc
    5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
    Oct 2005
    I have a scan log from hp tuners, but I am such a novice I don't know all of what to look for. If anyone would be willing to help I can email it to you.
    I can't seem to figure out if it is possible to post to log here.
    thanks
