Results 1 to 4 of 4
Thread: ranny help please
    Apr 2005
    I just talked with a tranny guy about installing my HD2 for me. He said with the milage on my truck he wouldn't recomend it. I told him I wanted a little firmer shifts, and to beef it up for the stall soon to go in. He recomended letting him swap the accumulators and springs and turn up something to up the pressure for the firmer shifts, then when and if the tranny goes to build a beefed up tranny and save the shift kit for that one. Im confused. I thought the shift kit would keep the tranny alive longer I need some help bad now.
    2000 RCSB Z-71 6l swap 12.8 Gone but not forgotten
    2008 CCSB "tow truck" Slooowwww
    1999 RCSB "WRK TRK" 4.late but getting there.
    Apr 2005
    Saint John, MO
    How many miles does your trans have on it now?
    Base: 2004 Victory Red Silverado 1500 2WD RCLB, LR4, 4L60E, 3.73, HD Suspension, P245/75R16 Tires
    Mechanical/Performance: Nelson 93 Octane Tune (See Slamma's CarDomain.Com Page for more details)
    Apr 2005
    106k, but it seems to be fine right now. It doesnt slip , and shifts fine. I would like to keep it together a s long as possible, and firm up the shifts a little. I don't want anything harsh just firm.
    Apr 2005
    Saint John, MO
    You can probably get away w/ a TG kit, but be very conservative. There are definately some other valve body parts which should be swapped for new ones or upgraded. If done right, a TG kit plus those other items will make your trans shift better and last longer. Also good things to have are a "real" trans cooler, remote filter and bigger pan.
    If you feel confident enough to do it yourself, there are alot of good posts of parts lists and advice/tips on this forum and others.
    I say do it, but do it yourself. That way you know it's done exactly how you want it. And you'll learn a bunch.
