Help
So I own a 2003 silverado that originally came with a 4.3,I converted it to a 5.3 out of 2004. The engine came with the harness and computer. I had both computers tuned and still have the same problem. At 80 mph I'm at 2900-3000 rpm. I'm not the brightest crayon in the box I know it should be around 2200 give or take a little. The transmission worked fine before the swap. I'm not sure if it's msybe the tune, harness, trans or tcc.
- You may not post replies
- You may not edit your posts
