Results 1 to 4 of 4
Thread: 4.125 stroke
    McAlester OK
    4.125 stroke
    Has anyone maid a ls 6.0 iron block into a 421ci for boost I have the block bored .030 and have a 4.125 crank and 6.125 rods and custom pistons maid for it with a 106mm turbo. Been reading and seen where people are saying going to have oil problems and it's not recommended for boost. And now I'm second guessing my build. Any info will help I really don't want to go a different route cuz I've done spent a lot of money. Sorry if my spelling is bad..
    Sep 2010
    San Antonio, TX
    Only thing I have heard is that the side loads will be pretty severe with that much stroke.
    @J_Industries ON INSTGRAM
    TURBO MIC PERFORMANCE
    MAZZULLA OFF-ROAD
    KING SHOCKS
    [HOONIGAN]
    McAlester OK
    I'm just goin to put it all togather and rotate it and see what happens
    Pittsburgh, PA
    I personally would never use that combo with a standard sleeve block
    The 4" stroke has issues and that will just add more. If you want to use that get a longer skirt in that block or use a LSX block
    Depending on goal you don't need huge cubes and only wanting 800- 900 the stock motor is plenty
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
