The engine choices won't change much with cable or wire. The PCM options will. I cant remember off my head but there are pcm's that won't work with dbw and ones that won't work with dbc. A little research should get those answers pretty quick. The cable throttle body and 411 PCM will run a lot of stuff.
I have dbw and love it. The pedal did require a little bit of work to fit but it wasn't hard at all. I like the cruise control of the dbw the best.
97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
TURBO IN THE WORKS
