Results 1 to 10 of 14
Thread: what are you running for an OBS oil pan?
    Dec 2011
    Savannah, ga
    got my 97 truck lowered 4/6 and the stock truck oil pan has smacked the ground a few times and i want to get a shorter one before something bad happens. what are you guys running? i was just gonna order a ls1 pan but it looks like the sump gets moved forward and i'm not 100% sure it wont hit the frame. the hummer pan doesnt look to bad but its only 3/4 inch shorter according to the ls1tech thread.
    1997 RCSB, AES 390 + 4L80E transplant, F1A Procharger, #160 injectors, Magnafuel 750, Schoenfield Longtubes, 3" flowmasters, Steve Morris Bullit cam, Circle D 3k stall, Ford 9" rear, Homemade Caltrac bars.
    Nov 2004
    I've got the hotrod/h3 pan. It's really is only about 1" shorter than the truck pan. It's also about half the price of an f-body pan. There's a few around here running sectioned truck pans.
    Apr 2014
    Quote Originally Posted by 12thstreetjunkman View Post
    Does it hang below the frame?
    Jan 2014
    Las Cruces NM
    97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
    TURBO IN THE WORKS
    Dec 2011
    Savannah, ga
    Quote Originally Posted by Chevydillan View Post
    yeah i was looking at that but i'm not home to measure mine figured it would be easier to ask lol
    Dec 2011
    Savannah, ga
    where did you get it from? i saw a few sets with pan gasket pickup and other parts for $150 on ebay for the hummer pans but they only look 3/4" shorter and 1/2 quart less oil
    Nov 2004
    It prob does hang down maybe 1/2" below crossmember, hard to tell here's a couple pics
    Looking straight down the middle from the front. Can barely see it peeking below crossmember
    From angle behind tire can see it hangs down maybe 1/2" although kinda looks more it's not.
    I think I gave $125 for mine off ebay, was new, the f-body setups usually run about $250 or so, but like you said earlier, the sump is longer, I don't know if it would clear crossmember front to back. I think it's pretty much the best option unless you want to section the stock pan. Could probably maybe put some washers in between mounts and adapters and gain another 1/4" if wanted to get it tucked up a lite more. I don't know if I'm as low as yours, but I don't really feel uncomfortable about driving it. I'm pretty sure the big block pan was below the crossmember.
    Spiro, Oklahoma
    The F-body pan will work, I'm using one with 1" setback motor mount plates.
    1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
    Dec 2011
    Savannah, ga
    sweet thanks guys
    Aug 2014
    I'm also using the h3 pan kit from eBay, works great with no issues and my truck is dropped 5/7
