I hope this is in the right area and hope that it is ok since the motor is not an LS.
I have a 6.0 lq4 fromt a 01 yukon. The trans is a 4l60e from a 00-01 1500 truck 2wd.
I am thinking of swapping out the trans with a 4l80E but was curious if i do this if there are things that i need to take into consideration before i order any parts?
Mounts and so on.
I work at a salvage yard so i have access to alot of the parts if need be.
I am swapping out the Drive by wire to Drive by cable and swapping the ecm for a 00 ecm from a drive by cable truck.
This is as far as the decisions that i have made at this point.
