Results 1 to 2 of 2
Thread: Transfer Case Choice
    Aug 2014
    I'm thinking of going with a late NP 246 transfer case in my L94 swap, but I'm wondering if there is any compelling reason to go with one of the newer transfer cases? (2008+) Is it even possible/reasonable to use one these in a swap into a 1992 rig? Anyone have any experience with this? Thanks!
    Aug 2014
    OKay, not much experience here, so I'll post what my research has shown. Seems like the newer 2007+ transfer cases are only minor improvements--if that--over the NP246. Plus, swapping the newer cases into older rigs seems to be much more difficult. The 246 uses onboard sensors whereas the newer cases use sensors and computer connections from the donor chassis. Anyways, if anyone knows different please post up!
    1992 K1500 Blazer.
    L94 & 6L80
    14 Bolt SF axle w/11" brakes & appropriate Combination brake valve, Eaton Trutrac rear posi.
    8000# hidden winch, Rocket Box, KYB Monomax shocks
    285/75R16 Duratracks
    Flat Panel Display Gauge cluster in progress.
    http://www.ls1truck.com/forums/lsx-t...00-blazer.html
    New interior & exterior paint planned.
