Hi All,
I'm chasing a water leak and I've got the interior completely gutted out of my regular cab. My factory speakers are toast so it's time to do a small system. I've got enough FatMat to cover every square inch of metal inside the cab.
I listen to my iPod 99.9% of the time. I would like to leave the factory head unit intact for the few times I actually listen to the radio and run an MP3 player along side it. Is it possible to have some sort of switch that will allow me to run the iPod straight into the amp and then flip over to take the high level inputs from the radio? This way when the iPod is playing I can control the volume right from the iPod and leave the factory head unit turned off.
I want to run all Cerwin-Vega hardware. I'm thinking a set of 6.5 components in the doors and two 10" subs behind the seats. Here are links to the components I'm thinking of using.
Components: http://www.sonicelectronix.com/item_...ega-V465C.html
Woofers: http://www.sonicelectronix.com/item_...ega-V104D.html
I have never worked on audio stuff so I need some guidance on 4 channel vs 2 channel and how much power I need. Maybe I only need 8" woofers? Where can I get a sub box to go behind my seats? Etc. Here's a couple pics of my stripped out cab; I really miss this rig and need to get it back together.![]()
