ok guys, someone has to know for sure, the 100% truth on this.. Heres the deal, i have a 1999 silverado extended cab shortbed 4x4 with the 4.8 engine and 4l60e trans, all original. I want to swap in a 6.0 and keep my 4l60e and stock torque convertor and all, will beef up the trans to hold up to the 6.0.
Ok, From what i have heard, in order to use my stock convertor and 4l60e, i need to find a 2001-up 6.0 to avoid the oddball longer crankshaft. ok, that would be no problem, but i read somewhere yesterday it needed to be a 2004-up to avoid the oddball longer crank, so back to the drawing board.. Does anyone know the truth? I know an LQ9 would bolt right up seeing as they were mated to 4l65e and 4l70e, but most likely it would be an lq4 that was mated to a 4l80e that i would use being as they are cheaper, but, will the lq4 work, even if it is newer than 2001 or will it STILL have the longer crank? I am looking at a 2004 lq4 out of a savanna van and another 2003 lq4 from a 2500 truck, will they work or will they have the dreaded longer crank? I dont wanna mess with having a custom convertor made or any of that, i just want to pull out the 4.8 and install the 6.0 and be done.. anyone know the truth? If all year lq4's will be a problem with the longer crank, i guess ill have to save longer for the lq9, need to know the truth before i buy anything..This is already being done on a tight budget and i sure dont want to order an engine and it not work without custom convertors and all.
Thanks
mopower440 is online now Report Post Edit/Delete Message
