Alright I will apologize in advance, I know this info is probably out there somewhere but I have been looking for the past few days and I am just running out of time for answers to my questions, so I appreciate any info.
I bought a 2006 RCSB auto V6 with the intention of swapping in a 5.3 V8 I already have from another project. I plan on adding some performance parts (turbo, cam, injectors, 4l80, ect) later on, but right now I just want to get the swap done, then later after I have gathered parts Ill tear back into it.
I am not sure what year engine I have, but it is a 5.3 with a drive by cable TB. I know it is not ideal, as the 06s had a drive by wire setup, but how hard will it be to make all this work like a factory-ish truck? I have seen its easiest to have the same year engine and harness that match the year of the donor truck, but with the TB differences I have, should I change the TB or leave it DBC? Will the rest of the connections be the same or will I need to butcher a 06 harness. I don't mind changing pinouts, but I would rather not get into cutting and splicing harnesses.
I know I will need to retune the ECM I have, and just planned on buying HP Tuners and doing it myself, as Ill need that later anyway. So here is a list of the parts I have seen I will need...
5.3 engine with all accessories
06 5.3 motor mounts
06 5.3/4l60 engine and trans harness
Retuned ECM
Also, I plan on swapping in a 4l80e, would it make things a little easier to just do that now? I want to run a full manual VB with pistol grip shifter, and I do have a 4l80 wiring pigtail laying around... Been looking at Transgos HD3 kit, any opinions/experience on that? The ECM I have is programmed for standalone right now with a "manual" trans. Would I be able to get a auto trans program back in the ECM with HP Tuners if I keep the 4l60 and run it as if it was stock?
