2001 gmc z71 5.3 w ls2 cam need info
I am new to this site and would like to start by saying thanks in advance for any help
which I may receive!
I built a 5.3 for my 01 z71
I put the flat top pistons in it and a set of 243 casting heads
I also put a ls2 cam and the ls2 front cover with sensor on it I changed the wiring
as ness and now I'm setting a p0342 cam sensor low voltage code I've never had any
issues with the cam sensor wiring before now
please help as I'm a little confused 01 is a 12v system and the ls2 sensor is a 5v
setup what can I do?
- You may not post replies
- You may not edit your posts
