Results 1 to 6 of 6
Thread: Best heads for a boosted 6.0L
    The Garage
    Like the title says, what would be a good set of heads for a boosted 6.0L? To be more specific:
    -I can commit around $1500 to a set of heads
    -I prefer thicker decks
    -I'll be throwing about 15 psi through this engine
    -I'd like a set of heads that flow like, or better than, 317's
    I've entertained the thought of obtaining a used set of 317's and just sending them to west coast cylinder heads or one of those companies that specialize in heads, but I'd also like to know where I can buy a good overall set of assembled and ported heads that will work well with what I am trying to do. This build won't be anything crazy. I'm only looking to make up to 800 at the crank, maybe the tires. I've been away from the performance domain for a few years now, so I realize I may be asking a question that has been answered about 27 times already. Suggestions?
    Dec 2008
    South Carolina
    Ever thought about an L92 top end?
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
    Pittsburgh, PA
    to make 800 FWHP any head of the LS motors will work...if you want to spend the coin then look for a set of used ported 317s or etc all depends on compression goal
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jun 2004
    george west texas
    I have a set of these:
    GM PERFORMANCE AS CAST RECTANGLE 260cc LS3 HEADS WITH PAC DUAL SPRINGS, SEVERE DUTY INTAKE & INCONEL EXHAUST VALVES.
    brand new but slightly used as they been down the track 6 times.....pm me or farmtruc if interested
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Arizona/Utah
    I say send some 317s off to WCCH they might as well be the gods of heads and should fit your budget. 243s are another good option if you want more compression. 317s and 243s are dang near the same with different combustion chambers. I would stay away from factory casting rectangle heads if you are concerned about deck thickness. If it were me I save money for other things and get some mild worked 317s.
    wichita falls, tx
    If you are interested I have a set of mildly ported 317's with larger valves.
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
