			NBS exhaust on OBS
					Will the exhaust from a 99-07 classic extended cab fit a 98 extended cab decently? I'm assuming the hangers will have to be moved and I would be bolting it up to pacesetter longtubes and offroad Y pipe. I would bring it to a muffle shop and have them do everything, but I'm looking at cheaper, DIY options without having the ability to bend my own pipes.
					I do just that on same type of truck I used an off-roady pipe from jegs and dynomax by 3" single exhaust for a 02 extended cab silverado and worked great just had to shorten the pipe that goes over the axle and modify two exhaust hangers
- You may not post replies
- You may not edit your posts
