Results 1 to 9 of 9
Thread: Any reason NOT to buy a PLX DM-6 wideband
    Jan 2014
    Las Cruces NM
    I was going to buy the tried and true innovate lc-1 with a gauge. I have had them in the past and they do the job well. A friend of mine has an PLX DM-6 and I really like some of the features. It can be set up with a graph in the middle so you can get a quick view of what's going on. It may be a little rice, or maybe not really more worried about it just being a good set up. I know it can change colors and all that bs but aside from that.
    Any thoughts?
    http://www.plxdevices.com/product_in...DBDSMAFR_DM6G3
    97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
    TURBO IN THE WORKS
    Apr 2012
    LaVista Ne.
    The only issue I have had with mine is the cold. It scrambles the digital part in the morning. Once the truck is warmed up. I just restart the truck and it is fine.
    Pittsburgh, PA
    stay way from a LC1, junk product
    no experience with the PLX
    but i run autometer in all my rides
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    PLX for years without any trouble easy install
    Simple: 408 on steroids!
    single digits coming soon!
    Jan 2014
    Las Cruces NM
    Alright. Thanks. I'll get one on the way.
    San Antonio, TX
    Same here. Plx.
    Jan 2014
    Las Cruces NM
    It should be here this week. I want to run their, PLX, fluid pressure sensor as a fuel pressure gauge. Now will I just need the sensor and harness and it will plug into the controller for the wideband or will it require a whole new gauge and all?
    TURBO IN THE WORKS
    San Antonio, TX
    they don't have a fuel pressure sensor/sender, just an oil pressure; unless it was just updated.
    been waiting on that for years!
    Jan 2014
    Las Cruces NM
    No still just that one, however lots of people using that sensor for fuel pressure and even PLX says it can be used for fuel but the sensor will need to be replaced more often. Guys have been going on 2+ years with no problems. I'm going to give it a shot
    It's an old thread but
    http://www.plxdevices.com/forum/view...hp?f=11&t=1807
    TURBO IN THE WORKS
