Results 1 to 7 of 7
Thread: Need Help Finding Right Torque Converter
    Apr 2014
    Hello All!
    I have previously posted this question on another sight and was quickly referred to this sight to ask my question, So hoping someone can provide some guidance.
    I am a new owner of a 2002 GMC Sierra short bed 2 wheel drive with a modified 5.3 and supposedly, a 4l65e transmission. I bought the truck with what seemed like a well built 5.3 with only 15,000 miles on it per the previous owner. I figured I could fix/change a few things to make it my ideal truck. In doing a bunch of preventative maintenance/work to make sure it is reliable I have discovered a major issue with the snout of the crank (keyway is elongated about 1" wide allowing the balancer to slip back and forth). This requires the bottom end be opened up and crank replaced, and repairs to be made. While everything is apart, I would like to remove the 3,600 stall converter that is (supposedly) in the truck. I would say the 3,600 is probably about right as it does stall up pretty high, but I would like to get back closer to a stock converter for driveability and better mileage. This is my daily driver. I am old school and this is first modified "modern" computerized vehicle. With that in mind, I am asking for your help to determine what converter to get. The following is a list of what I understand the modifications to be on the truck.
    243 heads milled .0030, comp cam springs, trick flow push rods
    flat top pistons
    216-220 114 lobe center 560-560 lift cam
    K&N Intake
    80mm throttle body
    greentop 42lb injectors
    headers, custom exhaust with high flow converters
    4l65e transmission with corvette servo yank (don't know what this is)
    3600 stall converter
    4.10 rearend gears
    Thanks for any help and advice you are able to provide.
    Arizona/Utah
    That cam will need a decent stall speed but as fun as the 3600 is it isn't necessary. I would suggest the budget trailblazer stall from circle d. It's a 2800-3200 stall that drives like a stock stall until you really smash the skinny pedal.
    Mar 2013
    Long Beach California
    Yank is a brand name which I'm assuming is who your converter is made by (which is Will well respected btw). As kerrgie stated, I have CD's 2800 tc and I love it. It really let's you get into the power band but still allows great streetability for a daily. Although you can SLIGHTLY tell its there because you do have to give it a little more gas to get the truck moving from a stop.
    Apr 2014
    Thanks for the responses! I will search for converters in that range. Also, if this is a 4l65e transmission, it looks like converters that are for a 4l60e trans will work...correct?
    Quote Originally Posted by AZ02 View Post
    correct, but why not call Yank and see what they would charge to restall the converter you have? just a thought
    Simple: 408 on steroids!
    single digits coming soon!
    Dec 2012
    El Paso, Texas
    I love my 3000 stall from Circle D. Drives stock pretty much until I smash on the fun pedal.
    The torque converter is the same for the 4L60 and the 4L65.
    2002 Burb-Dual Red Top Optimas, CAI, Jensen Indash, 2 15" Fosgate T2's in 10 cu.ft. box tuned to 35 hertz, LED tails, pulley, MSD wires, headers, Flomaster Super 44 with dumps, cam and valvesprings, painted grill shell and bowtie, led interior, plastidipped rims
    Dec 2008
    South Carolina
    I have a circle d 2600-2800 278mm stall for sale...I went to the 3000-3200. Shoot me a pm if your interested
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
