Results 1 to 5 of 5
Thread: True Bolt in 9"
    May 2012
    Floresville
    True Bolt in 9"
    We now offer a "True Bolt In 9"
    Stock brakes whether it is disc or drum, they will work.
    $1600 For housing and axles. 3rd member prices vary
    Pittsburgh, PA
    With using stock brakes what ends are you using?
    Do you have a close up pic of the welds?
    The perches, roughly what angle do you have them welded for?
    What spline axles are you providing?
    Does the housing have a fill port?
    May 2012
    Floresville
    Quote Originally Posted by George C View Post
    31 on up on the splines.
    I can add a bung for an extra $50
    Ends are custom not available off shelf.
    Perches are where they belong, pinion angle is able to be changed by build.
    Pittsburgh, PA
    Will you be willing to sell the ends?
    With my 14bolt I have the pass shock flipped
    And have my perches set to -3.5* I don't use shims as why I was asking
    And are you tig welding or migging everything
    Pittsburgh, PA
    how much for a 9" with the ends but no brackets or perches welded on and a set of 35 spline 6 lug axles?
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
