Results 1 to 4 of 4
Thread: ECSB 4.3 to 5.3 Swap
    Feb 2014
    Gloucester, VA
    Post ECSB 4.3 to 5.3 Swap
    This is my 4.3 to 5.3 swap/mild build
    2003 ecsb silverado 4.3L 2wd 207,xxx miles $2200
    1999 sclb silverado 5.3L 4wd totaled rust bucket with cooked trans. 138,xxx miles $600
    Parts I've Acquired so far:
    Comp 220/220 .581/.581 .112lsa cam
    3200 stall convertor from Circle D
    Precision Race Components .625" Single Beehive valve springs
    Texas Speed & Performance 7.40 Chromoly push rods
    Egr delete kit
    Tow Max Trans temp gauge
    Tru Cool Trans cooler
    CAI
    Shorty Headers
    3.73 Gears
    Vette Servo
    Trans go HD-2 shift kit
    E fans
    Coming soon:
    Nelson Performance Mail Order tune (Heard nothing but great reviews)
    Pacesetter long tubes
    Custom 2.5" dual exhaust with X pipe (not sure on muffler if any)
    Ls 6 intake manifold
    Underdrive pulleys
    Pics: (crappy phone pics)
    Motor still in the doner truck
    Unpluging the harness form the truck getting ready for engine removal
    After selling the front clip off the truck, finally getting to pulling the motor.
    Motor on the stand with wiring harness still attached
    Starting the clean up after removing the intake manifold and front accessories
    looking rough
    Finally some parts start coming in. Big thanks to Texas Speed for a fast delivery
    ill post more updates as i get further.
    Feb 2014
    Gloucester, VA
    The truck it'll all be going into, (needs to be de-chromed,a little altitude adjustment and some new shoes i know)
    Feb 2014
    Gloucester, VA
    after the cam & valve spring install, motor still looking rough.
    Cleaned up and painted
    had some down time at work so i got rid off the dumb looking chrome grill and fender flare/trim? heres some pics of the grill.
    Feb 2014
    Gloucester, VA
    Ok, so its been awhile since ive be on here heres some progress so far..
    old and worn 4.3 is out
    ran into some problems with the motor mounts passenger side v8 4x4 mounts working perfectly but the diver side was way off so ended up having to make an adapter plate out of 1/2 steel to make the 2wd V6 mounts work
    "These are not the bolts i used, they were just for mock up"
    heres the engine sitting on the new mounts
    intake and front drive assembly on (Dirty)
    every thing in and plumbed up still waiting on the harness..
    3" exhaust with dynomax race bullet no cats..
    trans cooler in and mouted
    trans temp gauge and fan switch
    finally got my harness back from current performance they repinned to work with my 03 fuse block.
    just received my tuned PCM from nelson
