Results 1 to 5 of 5
Thread: Manual to auto swap can it be done
    Truck is a 99 he said 5.3 but I think 4.8 but it has a manual that's messed up and I want a auto can it be done
    Mar 2013
    Long Beach California
    of course. why not??? they came in automatic too... just get all the mechanical parts needed, harness for the trans and a retune. i assume you will need to swap steering columns or somehow mount a floor shifter. if u just get all OE stuff, should all bolt right in.
    CALI LEGAL ENGINE SWAP!
    So u do have to buy a transmission harness and different fly wheel I assume but I was told that when a ls engine came with a standard that the crank in the engine would only allow for a standard trans fly wheel is that true?
    Jan 2012
    DFW, TEXAS
    whoever told you that must drive a ford!
    Pittsburgh, PA
    Quote Originally Posted by Fatnasty91 View Post
    some of that is true. Early 48s had a different crank that were matted with the manual trans. Later yr motors no issues
    thinking only the 99 4.8 had this issue
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
