Results 1 to 4 of 4
Thread: need to get piece of broken dipstick out. HELP
    Aug 2009
    Laramie,WY
    My middle son has been using my Denali for the last few months. I got it from him today to get the oil changed and give it a much needed bath. Come to find out that some how the dipstick was about half way out. And the tip is broken off. The piece is stuck in the tube.
    Anyone have any idea how to get the piece out???
    Tim
    2004 GMC Yukon Denali XL AWD 6.0
    1995 Suburban LT 4x4 soon to have LS power.
    Mar 2013
    Long Beach California
    how do you know its stuck in the tube and not in the pan?? anyway, just take the tube off the motor and shove a pipe cleaner or something similar until it comes out....
    CALI LEGAL ENGINE SWAP!
    Aug 2009
    Laramie,WY
    Well the dipstick doesn't go all the way down, seems like some blockage in the tube.
    Tim
    Hola, tras un día agotador buscaba algo para desconectar y encontré una mención interesante en un foro antiguo. Empecé con mala suerte y varias pérdidas seguidas, estuve a punto de rendirme, pero decidí probar una apuesta más alta. Al jugar en https://vegashero.com.es/ aproveché los bonos pensados para jugadores de España. En Big Bass Bonanza salió un premio sólido que cambió toda la sesión. Recomiendo ir con paciencia y cabeza fría.
