90 GMC C3500 dually 6.0 4L80E swap in Frankentruck!
I've got this thread going in another site, going to condense it here.
This is how my truck was when I started Just finished almost the entire truck.
and a bunch of dudes that had a chop shop seemed to take a liking to it also. Oct. 2nd around midnight they took it. fortunately my club has friends in Legal places and within 2 hours of me posting the news on facebook a detective saw it roll into the chopshop he had been watching for 6 months.
long story short he had to wait till all the guys put a hand on it so he could bust them all and they had stripped it down pretty good by then.
got it back the next day and decided its time to use a crappy situation as motivation to do some upgrades.
I had an 05 express 3500 with 74,000 miles a 6.0 and 4L80 so I got to chopping!
pulled the engine, trans, entire harness inside cab and under hood and lights!
I'm also using the fuel tank from the van being its the 15 passenger it had the bigger tank, fuel lines, cluster and column.
I've also picked up a 95 dash, 95 doors.
To start with I already had 99 seats, overhead console rear seat and center console in the truck, 5-7 drop, Alcoa wheels, custom paint, rear helper bags with tank and compressor, etc... etc... way too much to list.
The Plan is to use the 95 dash, 95 door guts and panels, 05 cluster, the entire 05 harness including lights. 05 column (surprisingly fits the 95 mount)
I know I need to change the column / brake pedal mount, already started that too. and of course the 05 6.0 and 4L80.
so Far I have stripped the van for all its goods, pulled the old dash and harness test fit the 95 dash (fits great)
and today pulled the dash and all wiring back out and started taking out my 454 TBI and 700R4 got everything ready to come out, hopefully will get it out in the morning.
12-16-13
got back into it tonight, didn't have allot of time but I did get the 454 and 700R4 pulled out. got most of the wiring out of the truck and started prepping the 6 liter and 4L80 to go in.
still need to get the rest of the wiring out after I finish gutting I should only have the taillight and trailer wires left, everything else including dash wiring, door wiring etc is coming from the donor.
looks like the fuel tank and lines from donor are going to work too!
so I will pretty much be reinstalling all of the 05 wiring into the 90 cab / chassis. just have to splice in the tail lights. and 95 door panels.
heres a few pics from tonight. didn't take many when we tore the van apart to get all the donor parts.
Out with the old.....
need to get in here and clean and paint..
heres the new 6.0 and 4L80 standing by!
have not done a full swap with all wiring and electronics included before..
im using the column and cluster from the 05 also!! didn't have to cut anything!!
cluster works great!! and yes that's the actual mileage from the donor, Owned it since new till one of my employees got T-Boned!
12-20-13
anyway, a little more progress tonight.
stabbed the engine and trans in to figure out how I want to do the motor mounts, im extremely confused as to why people are cutting up their trans cross member or using adaptors? I was able to unbolt mine and slid it into place. once I get the motor mounts done it looks like it will bolt into existing holes in the frame that were behind the stock mounting location.
going to blast it and paint it while its out. now that I have an idea of where the engine will sit and see everything clears I can pull it back out and clean and paint the engine compartment.
done for tonight, will get back on it tomorrow. Hope to get allot done this weekend.
12-21-13
Beyond excited with todays progress, got the engine and trans in!
I ended up sliding back the existing trans crossmember and mounted the trans to that. then we played around with the motor mounts and ended up cutting the frame mounts from the van and retrofitted them to the truck. total cost =$0
so now my truck is using the stock 05 express van 3500 motor mounts.
lots of room. under the hood compared to the 454. amazingly the driveshaft is perfect, just need to swap the yoke to the one from the van.
only got in a few hours today. tomorrow I can clean the hell out of everything and work on getting the van fuel tank and lines in and then start routing the wiring and hope to have time for the column swap. Maybe start putting it back together.
here's a couple of shots I took from my phone.
Looks goooood in there!
12-24-13
here's a shot of the way I did the motor mount.
we took the engine mount perches from the van. they bolt to the frame in the van, after cutting the stock frame mounts off the frame of the truck we could then cut the van mounts down to contour the frame of the truck.
we bolted them to the engine, when the engine was in the correct spot I tack welded them to the frame. unbolted the engine and finished the welding and shot some black paint. saved quite a bit of money not having to buy adapters.
Taking a break for Christmas will get back on it later in the week!
hope to a have a video of it running soon!
Merry Christmas everyone!
-Jim
- You may not post replies
- You may not edit your posts
