so ive got a U1301 code showing up. im pretty sure this is not an emissions related code and its not too important as its not illuminating the CEL. but for one, its bugging me to see it, and two, im not sure if the BAR ref will care or not that its there so id like to get rid of it.
ive done research on it and its caused either by serial data short to battery positive or its not communicating with other modules (BCM,TCM, etc) i drove around with my meter hooked up to pin 2 and 4 on the DLC and monitered voltage. the "normal" seems to be around 0.38v and the highest spike i saw was 1.3v Also i only have the PCM in the car. so im thinking its not a short to battery, but its just not recieving signal from the other modules.
does my diagnostics sound right to you? i know nothing about the data part of the system so i was hoping you tuning guys could shed some light.
if thats all the problem is, can that be tuned out without hurting anything? also it says if this code is set, it blocks all other U-codes from being set. im wondering if there are any others that may pop up for no reason after that should be tuned out at the same time?
