Results 1 to 7 of 7
Thread: Looking to run 35s, will they fit?
    Jan 2012
    Anacoco, La
    Hey guy, im running 33s now and its getting time for new rubber. I wanna run 35s. I have right at 5 1/2in over stock now, will 35s rub? Seems like ill have room just not sure. Also how bad is that going to throw my speedo off with 4.10s till i can retune?
    wichita falls, tx
    What kind of truck and that are the specs on the wheels?
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
    Jan 2012
    Anacoco, La
    Its a 2000 silverado ext cab, wheels are procomp xtreams 17 by 8 1/2 i think
    Jan 2012
    Anacoco, La
    The fella at the tire place said he wasnt sure if they would rub inside the fender when i turn, im running a pro comp xtream mt now 305-65-17 i wanna go 35-12.50-17. Id like to fill some fender space, iv got close to a foot and a half from the top of my tire now, make the wheels look small lol
    wichita falls, tx
    Do you have any idea what the off set is on the wheels?
    Jan 2012
    Anacoco, La
    I have no clue, they were originally for a titan, i had to put fender flares on cause the tire sticks out about an inch outside the fender, and they threw mud over the top of the truck. I tried to upload a pic so you could see but it dosent work.
    wichita falls, tx
    They will fit BUT without knowing your offset I don't know if they would rub or not. My guess is if they are sticking out an inch then they may rub a little but nothing that a little trimming cant fix.
