4L60E to 4L80E Conversion Tubular crossmembers.
As of now these just fit 99-Early 2000 and Later 2000-07 classic 2wd trucks.
Tubing is .120 wall mild steel and the brackets are 3/16s mild steel. Everything is welded in a jig and will clear dual 3" exhaust. Ive tried to give as much as exhaust clearance as I can. Everything bolts in factory position, just look at the pics.
Weighs around 5-6 lbs
$140 Shipped
99-Early 2000 trucks
