Results 1 to 5 of 5
Thread: 5.3 part out
Threaded View
    5.3 part out
    I bought this engine for spare parts, and its just in the way. I need it all gone... The engine has two spun rod bearings, so the crank is probably shot along with the two rods. Everything else is in good shape.
    5.3 bare block (good std bores, mains, and cam bushings) Hone and go. $100
    5.3 862 heads with valves, springs, keepers, rockers, and bridges $100pr
    5.3 truck intake with cable throttle body, rails, and injectors. $75
    Coil packs w/ brackets $50pr
    stock exhaust manifolds $50pr
    misc brackets, covers, cam, crank, rods and pistons, fan w/clutch, cut wiring harness, ect ect $100
    OR TAKE IT ALL FOR $275!!
    Bodie
    210-391-5811
    Located in San Antonio, TX
    87 Samurai 14b f&R 5.3/350/205 42s
    04 H2 NP tune 6" w/ 37s on 22x14s
    04 Dodge Laramie Cummins
    04 SRT10 w/twin turbo Cummins
