I need help figuring out how to properly wire the vss up. I have nelsons harness. It has 3 speed sensors but only 2 of them are used. The very front one isnt used because it is a 4x4 truck. My truck uses the 2nd ( plugs into end of tranny, and the third one plugs into the transfer case). My problem is truck doesnt want to shift out of first. You have to manually shift it yourself to get it goin, then its fine. I am gettin a code on the scanner saying vss circuit bad signal so I know something is wrong. Please help with input for a 4x4 truck! Thanks
