as stated, i want to know if my axles will handle the end goal of my build. so i have a few questions before i start purchasing things for what i have now.
i got the new motor in and running and now im about to do the 80e swap to handle the newfound/future turbo power. ive got the g80 rear end with 3.73's. ive looke but cant find a for sure answer on what it can handle. im planning on pushing the 500-550 hp max that the motor can handle in its stock form. so with the 80e, i know im good up until the rear axle.
will the stock unit handle this? for how long? are there bigger splines that still fit with same bolt pattern or will this require custom axels? dont want to change bolt pattern due to my new rims.... if i need to upgrade axels, might as well do gearing at the same time right? what gears would be good for the future setup? i will OCCASIONALLY go to the track but it will be mostly for street so i dont want super steep gears...
sorry for the long post. i just dont know much about the rear ends and what is good for what. i see some of you full blown on what looks like a street truck....are you guys running stock 1500 axles???? i just need to prepare myself on what i need so i dont have to do things twice and spend wasted money if i can plan out my steps.
