Results 1 to 2 of 2
Thread: Powdercoated 99-02 ECSB 4x4 frame and all components
    Frame is from a 2001 silverado extended cab short bed 4x4 5.3/60e/246. It and all components have been blasted and powder coated black. The only things that were painted were the control arms and the torsion bar cross member mount due to the rubber joints. They were also blasted before being painted with ppg car paint and clear coated. Truck was never wrecked, and could be used 99-06 with the front frame horns changed.
    It includes : tow hooks, front sway bar, front spindles, upper and lower control arms, small backing plates behind front wheel bearings, front brake line/hose tabs, motor mount brackets, cross member under front differential, transmission cross member and supports, torsion bars, torsion bar keys ,torsion bar cross member, torsion bar cross member mounting brackets, skid plate, and rear bump stop mounts.
    $1000 FIRM
    I have a LOT invested in this and a lot of time, if it doesn’t sell, ill just assemble the truck like I planned
    Located In Pittsburgh, PA , Local pickup only
    Bump
    Sold the spindles, small backing plates behind front wheel bearings, brake line tabs, and Transmission crossmember.
    $500 for everything else. If it doesnt sell this week, going to the scrap yard
