So what the difference between some milled 862s and some stock 243s? Also how big of a difference would the 243s and a nnbs intake do on a 2003 4.8?
4.8 FBO-PULLEY 228/228 CAM 4.10 GEARS TUNED BY NELSON...JUST CRUSUIN SAN ANTONIO!
Not to thread jack but I'm interested in this myself. I've read that 862 ported and milled will do wonders on the 4.8/5.3. 243 would have to be milled from my understanding just to get back to factory type compression. I could be very wrong but I'm going to have a set of 862 worked and see because they are usually cheaper. Hopefully someone with more knowledge and experience will chime in.
If you can get the 243s cheap then I would probably go that route if your running the cam in your sig. I would think just milling those to get back to stock compression would be a nice upgrade and may be cheaper than working the 862. I would also contact your tuner because if you aren't already you will be pushing the limits if your still running stock injectors. Just a thought. Hopefully some one else will shed a little more light on this.
May also have to worry about ptv clearance as well with 243 if your doing a lot of milling
The reason 862s work well is because they can achieve a higher CR. The 243s flow much better but require a heavy mill to get the compression back to stock.
