Results 1 to 9 of 9
Thread: First time at the track with the lsx c10
    Feb 2009
    Well I went to the track this past weekend with my 1978 with the LQ4/4L80E, and my assumptions were correct. I need trac-bars BAD. The rear end rapped pretty bad and it wheel hopped from a hard dig. There was visible damage to the u-joint strap bolts, because the bolt heads made contact with the drive shaft at some point. When the truck was lowered they used aftermarket hangers and removed leafs and a wedge to rotate the rear for pinion angle (non-flip kit). So the leafs are pretty weak.
    I rolled it off the line with the drag radials (325/50/15) at 14 lbs and the truck went best of: 12.87 @ 105 with a 2.00 sixty foot. I played with the truck off the line and went 12.99 @ 105 and 12.90 @ 103
    If I can get the sixty foot down I'm thinking 12.50's
    My plans are to build cal-trac "like" bars.
    I need to order the solid spring eye bushings, I've already bought the heim's and got some scrap metal around the shop. So now I just need the time to build the damn bars.
    81 bagged shortwide: LS1/4L60e, porterbuilt crossmember, ART arms, back halfed, bagged on 22x8 22x12 intro V-rods.
    78 chevy swb: LQ4 tr-224 cam, longtubes, LS6 intake, 4L80e-3500 stall, 4:10, 325/50/15 bfg drag radials on 15x10 rallies
    03 dodge 2500 4x4 (tow pig) 6" superlift 22x14 and 37's
    94 exswb chevy LQ9 w/ L92's, with 4L80E in the works...
    Apr 2011
    Nice run need more pics
    2006 Silverado aka (Bad Bitch)
    K&N CAI, Diablo Predator, muffler delete, and a vette servo. 14.7x @ 93 mph (sold)
    1998 SS Camaro aka (Silver Bullet)
    LS6 intake, ported TB, LTs, ORY, cut out, and a pantie dropping tune by Nelson. 12.6 @ 110 mph 327 hp 347 tq
    2011 ecsb silverado aka (silver sleeper)
    forged 6.2 and a small snail
    Feb 2009
    I got a video on my iphone also of the run, but cant seem to load it..
    Jan 2012
    DFW, TEXAS
    and you dont want a 4 link?
    Feb 2009
    Nah, I'm wanting to keep the stock set up.. Or mostly a stock style set up.. And I've bought the expensive parts of the trac-bars already..
    I dont want it to spiral out of control like my 1981.. LMAO
    Dec 2008
    san antonio TX
    badass looking foward to seeing the vid..
    Mar 2011
    Mississippi
    Very nice!!
    * 2004 Chevrolet CCSB Z-71 5.3L * G80, 3.73's * Black Bear Autocal 91 oct tune * Magnaflow 3" SI/SO 14" case * Airaid M.I.T. * OEM airbox with open air modification * Color matched grille & lower valence * Blackened Tail Lights * SuperBright LEDs in brake lights & reverse lights *
    In the garage to be installed: 799 heads, Dyna-Tech long tube headers, Corvette servo, 2" lowering shackles, 2wd u-bolts & bumpstops
    Feb 2009
    Here is a video of my 78. The one at the truck didn't convert very well from my iphone
    http://www.youtube.com/watch?v=KWpN091zJfM
    Feb 2009
    This past Friday I finished my trac-bars and got them on the truck. Then Saturday a group of buddies and I went to Pinevalley raceway in Diboll tx, to hit the track.
    Well, the trac-bar worked well but did not drop the 60-ft at all. The truck ran 13.0 @ 103 numerous times and acouple of 13.1's. I tried leaving on the 3000 stall and even shocking the truck off the line to improve the times... Nothing was working. I even let a buddy pilot the truck acouple times to watch the truck leave. With the preload on the trac-bars the truck would wrinkle the drag radials (12 psi air pressure) no spin AT ALL.
    I've talked to some freinds about the performance of the truck and everyone seems to think the truck is hooking up so well that it is bogging the motor off the line and killing my et. I think when the truck was spinning alittle the truck would get the rpms up, and stay in the power curve. Hell the truck was running 105 trap speed.
    So the plan is milled L92's, L92 intake, a new comp cam 224/236 .581/ .601, and 92mm Nick williams throttle body and tunning. I've already got the said parts, I was planning on using them on my 94 ecswb with the Lq9.
