Results 1 to 10 of 13
Thread: Time for tires!
    Apr 2005
    belton, tx
    Need to buy tires for the 'ol truck. Any recommendation s for a good 20" performance tire? Looking @ goodyear gtII's, General Grabbers, etc.... Let me know what you think. Preferrably 285/50 20's.
    2013 2wd Z71 6.2 crew cab
    Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
    best time 12.93 1/4 mi @ 103 in the turbo truck.
    1968 Camaro Convertible, super sweet!
    Dec 2003
    Moregrip and Bud8fan have the goodyear gtII's and seem to like them. That's what i'm getting.
    2000 Chevy Silverado 2500 ECLB w/6.0 , 4L80E auto, 4.10 G80, K&N, Nelson Dyno Tune, 02 PCM STS TURBO , 44# injectors, IC ,HPTuner and 160* thermo 348 rwhp, 394 rwtq @ 5 psi
    60'=2.241
    1/8=9.352@77.39
    1/4=14.40@ 96.67
    May 2005
    IMHO I like the Nitto's. I got 50k on a set with out rotating.
    http://memimage.cardomain.net/member...607_2_full.jpg
    4-6 drop, 18" Centerlines, K&N FIPK, Flowmaster 50's dumped, Transgo HD-2 shift kit, vette servo, billet OD servo and Nelson tuned, 160* T-stat, Eaton posi and 4.10 gears.
    Jan 2005
    Humble/Houston TX
    havent ever seen a complaint from the toyo proxies. thats what im going for when im out of rubber
    old mod list: H/C/I/N/E/G 408
    Jul 2005
    modesto, ca
    A guy I work with runs coopers because there cheap, handle good and are pretty sticky.
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
    Apr 2005
    belton, tx
    I got an "in" on the Toyo's. I might get them. I couldn't find nittos in 20's. What model # are you referring to?
    Apr 2005
    belton, tx
    BTW...Truck ran 14.17 1/4 mi in cooler weather 82* @ night!!!!!!!!! !!!!!
    woohoo! I can taste the 13's
    Jun 2004
    george west texas
    good run...oh tires......there is sooo many good ones out there anymore you have to kinda go with what you like...you can go to the tire rack.com and check out the comments form all...
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    May 2005
    I run the 404 Extremes but now that I look at what you are running you may want something more than V rated tires. The NT 555's come in 20" and are Z rated though. Here are the specs that I found.
    404 Extreme
    *255/50 R20 109V 11.5 29.92 10.24 7.0-(8.0)-9.0 2271@50 694
    *275/55 R20 116V 11.5 31.89 11.10 7.5-(8.5)-9.5 2756@50 651
    *305/50 R20 120V 11.5 31.89 12.28 8.5-(9.5)-11.0 3086@50 651
    *305/40 R20 112V 11.8 29.61 12.17 10.0-(11.0)-12.0 2469@50 702
    555
    *275/35 ZR20 102W 10.6 27.60 10.91 9.0-(9.5)-11.0 1874@50 753
    *275/30 ZR20 97W 10.6 26.61 10.71 (9.5)-11.0 1609@50 781
    My bad I thought that the 555R which is a drag radial came in 20's also.
    Apr 2005
    belton, tx
    WISH I COLD GET THE NITTO 555 BUT THEY WOULD LOOK DUMB ON MY TRUCK. THE SIDEWALLS ARENT TALL ENOUGH.
