Newbie from Missouri
Been viewing for a few months now and finally joining in .I Have a 92 obs that I am in process of converting to a 6.0 w/ turbo 400 Just a low milage stock for now ,but plan to put a turbo on it .I made a few bad purchases early on on my harness and ecm (before I found this site) hope i can make it work or can get some help from nelson,the company I got it from reworked a factory haress and its pretty sloppy.
Well Its ALIVE! Kinda ,Been working at getting it running this week .Wiring is still a mess but it works .I kept the old computer for the 4.3 5 speed in the truck and cut out the wires that we didnt use.The harness that I got from just chevy trucks is a stand alone with no transmission controls (dont need with the 400) Dont thinks i need the stock computer at all as I unplugged it and truck still runs. I used the autometer oil pressure adapter and my sender from the 4.3 and gage works .not sure what to do for temp gage yet any advise would be helpful
Welcome. glad to have another swapper,the folks at Nelson will help you a bunch. As far as the temp sender,I used an aftermarket electric water temp guage and braized a fitting onto the adapter I got from speedway motors and put it in the pass side head. You have to drill out the inside of the fittings so the sender gets some water flow around it. It clears the spark plug boot and works fine. I should have drilled and tapped the head to fit the obs sender while the heads were on the bench,but thats water over the dam now! anyhow good luck with your truck.
Thanks ,Im a old drag racer from way back . I have been out of it for several year and this Truck I bought New and have been running the wheels off it . 250K miles with the 4.3 been the best truck Ive ever had. thinking about drilling that hole bigger for the factory sender in the passenger head havent got coolant in the motor yet . shop vac while in drilling should work (whats your opinion)
Thanks have got lots of great info on this site!
- You may not post replies
- You may not edit your posts
