Results 1 to 5 of 5
Thread: Garage sale on drivetrain parts
    Sep 2010
    North East Ohio
    parts pulled from 2010 Silverado 20-30k
    3.42 rear gear set 8.6 rear 100.00
    3.42 front gear set 8.25ifs 100.00
    G80 locker 100.00 SOLD
    TCI 1-2, 3-4 super servo with aluminum cover. You will need a seal kit that is about 10 bucks. 80.00
    Stock 4l60 converter just to get someone down the road. 75.00
    stock valve springs 20.00
    stock pushrods 10.00
    Shipping depends on item and your location.
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
    Oct 2011
    San Antonio TX
    Will the g80 fit all 8.6. I got a 03 silvy that needs one and ive heard that 2010 use different bearings.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Sep 2010
    North East Ohio
    The bearing difference is in the pinion. I will check the ID and OD on the carrier bearing tomorrow for you
    Cam, Stall, 4.88's
    Sep 2010
    North East Ohio
    bring it back up in case someone else is looking for parts
    Cam, Stall, 4.88's
    Sep 2010
    North East Ohio
    Just an update on this post if anyone is looking for these items.
    Flowmaster series 10 single chamber Race muffler 3" in /out, center / center 25.00 Surface rust
    Magnaflow Muffler brand new stainless steel. 11" performance version 2.5 in/out center / offset reversible 50.00
    Ractive Tuner race muffler 2.25 in dual tips out chrome 40.00
    TCI 4L60e billet servos 1-2 and 3-4 with aluminum servo cover 75.00 for both.
    Stock 4L60e torque converter with 20k miles on it. Original GM 80.00
    Stock 799 / 243 LS engine head valve springs and pushrods 25.00 GM
    Auxiliary transmission cooler 20.00
    3:42 Gear GM Gear sets 8.5/ 8.6 for the rear 100.00 also have 8.25ifs in same ratio 100.00 or 175.00 for both
    Factory 2010 GM Truck MP3 CD player with front ipod input 100.00
    Cam, Stall, 4.88's
