Hey guys! Newbie here with some questions about swapping a 6.0 into my 72 chevy. I already have tuned port injection on this thing, but it looks like the 6.0 is next for my truck!
I Did some searching around and came across this site.. you guys seem to really know your stuff so i figured i'd post a few questions..
I just picked up a 6.0 engine. I'm planning on dropping this in my '72 K/5 Blazer. Now on to my questions:
#1. The throttle body is "fly by wire".. can i convert this over to a cable actuated throttle body?
Is there a company that makes a conversion, or am i gonna have to go find a pedal assembly to make my '72 a drive by wire engine???
If i swap an earlier cable style throttle body all the connectors and sensors will work just fine eh?
#2. Its an '04 6.0 engine. I got the ecm with it, but want an aftermarket wiring harness. which one do you guys reccomended?
#3 Will the stock ECM work or will i have to have it reprogrammed for the VATS system? Who should i send it out to, to have this done???
#4 VSS? I already have a mechanical VSS for my TPI. Does the 6.0 require a VSS and will my tpi vehicle speed sensor be compatible?
This Engine is going in front of a manual 4 speed tranny SM465/NP205 combo...
So the transmission controls don't matter... Can i just leave all the tranny connectors unplugged, or will i have to have my computer reprogrammed for this also??
I'm sure there will be more questions as my swap gets underway.
Thanks a bunch in advance! I look foreward to making some friends on this site and getting help with this swap.
Ryan
