I will be selling them for $205 shipped anywhere in the USA, these units are new in the box never opened. I will be taking orders on them on demand. Soon I will be doing the Comp Hardened Pushrods as well. PM me for more info.
Specs are as follows.
COMP CAMS PART NUMBER #26918-16
BRAND NEW IN THE BOX COMP CAMS BEEHIVE VALVE SPRINGS FOR GM LS GEN III-IV ENGINES UP TO .625 LIFT.
COMP® Cams GM LS Beehive Valve Springs
With a .625" maximum lift, these Beehive™ Valve Springs were designed for hydraulic roller cams in LS1, LS2 and LS6 engines. COMP Cams® Beehive™ Valve Springs deliver increased valve train stability and a much lighter valve train. This is achieved with less spring pressure for better valve control and reduced weight of both the spring and retainer. The unique Beehive™ shape handles valve train stress more efficiently to eliminate damaging harmonics and increases high RPM horsepower and durability. The oval/multi-arc wire shape places the maximum area of the wire at the point of highest stress to handle valve train stress more efficiently and allow better heat dissipation for longer life. Because of the unique Beehive™ design, the valve train can handle more RPM and more aggressive cam profiles.
VALVE SPRING SPECIFICATIONS:
Part# O.D. I.D. Seat Load Open Load Coil Bind
26918 1.075 .650 125 @ 1.800 367 @ 1.150 1.100
Rate
(Lbs./In.) Titanium Retainer Steel Retainer I.D./O.D. Shims
Locator
372 772-16 774-16/1772-16 4705 4753
..........SOLD :-(
