Results 1 to 9 of 9
Thread: FS: 73lb bosch injectors from FIC
    Sep 2006
    THE 405
    Less than 1000 miles. Have flow sheet as well. $425obo shipped and paypal'd
    72 lb Bosch EV14 High Impedance
    Genuine Bosch High Impedance Injectors
    These injectors flow 73 lbs/hr at 43.5 PSI ( 3 BAR ) and more at higher PSI. In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector. These injectors represent the most current Bosch engineering and are used on many high power oem applications.
    These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. Many tuners push these injectors to 6 bar and higher.
    Engine performance and running quality are enhanced through the optimized spray pattern. Unlike competitors “pencil stream” high flow injectors; these High Flow injectors utilize a multi-orifice tip for improved mixture preparation and atomization. This results in lower BSFC and better idle quality than many injectors with less flow.
    Features:
    Genuine, reliable Bosch Injectors
    Excellent response characteristics
    Robust Design
    High Impedance
    Low Impedance performance characteristics with High Impedance Compatibility
    Specifications: Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
    Spray Pattern: Wide Split Cone, (6 orifice) OR SINGLE TIP
    Electrical Connector: USCAR (New-style V=EV6 / Oval / LS2)
    FUEL INJECTOR CONNECTION - 73lb Bosch LS 2 Injector Drop-In Set of 8
    midweststreetcars.com
    Sep 2006
    THE 405
    Would also sell the Aeromotive 13105 regulator pictured for $125obo shipped and paypal'd
    Sep 2006
    THE 405
    price is obo...
    ttt...
    Sep 2006
    THE 405
    Bump obo
    Sep 2006
    THE 405
    $425obo
    Sep 2006
    THE 405
    I have these adapters to go from the older truck harness to these injectors i'll throw in as well
    Sep 2006
    THE 405
    Will also throw in the height adapters to to adapt to vic jr, and ls1 style rails. $425obo
    Your truck was a 06' right ? My buddy has a 06' 5.3 were doing a turbo on ill forward this, he just wants a plug n go deal
    Sep 2006
    THE 405
    These will drop right in. No height adapters or wiring adapters needed.
    Thanks
