Results 1 to 7 of 7
Thread: 02 Sierra
    Oct 2008
    Tennessee
    02 Sierra
    2002 GMC Sierra scsb 81K miles
    Engine Specs, around 10k miles on motor
    HKE Preped LS1 block 3.905 bore 9.4-1 CR
    Mahle forged -16cc Dished pistons
    Compstar Rods
    Stock LS1 crank
    ARP head studs and bottom end studs.
    Comp Cam 226/222 568/558 115LSA
    Ported 706 heads with Gold dual springs
    LS6 oil pump shimmed for more pressure
    LS2 MLS headgaskets
    Double roller timing chain
    Transmission around 8K miles on tranny
    4L80E fully built by Transformance
    Deep cast alum pan
    Art Carr Billet converter 2800 stall
    3.5" driveshaft with 1350 slipyoke
    Remote mount turbo kit 2K miles on turbo kit
    Stock Cast manifolds
    Mandrel bent Y pipe Ceramic coated Black
    Turbonetics TC78 with a .96A/R
    38mm wastegate 7 psi spring
    50mm BOV
    Boost controller set at 12 psi.
    Alum. Front mount intercooler
    3" exhaust ,Thrush 2 chamber dumped before the rearend
    Fuel System
    Dual intake walbros
    Billet fuel fails with FPR
    60lb injectors
    LS 1 Fans Nelson Fan Wiring Harness
    Drilled/Slotted Rotors
    Guages
    White Face innovative wideband
    White Face Autometer Boost gauge
    Autometer Dual pillar pod
    12K
    Arizona/Utah
    Wow that's in sleeper mode for sure. GLWS!
    Pics of the exhaust/turbo setup?
    Mar 2010
    Paris
    Strait Sleeper!
    Oct 2008
    Tennessee
    Thanks,
    Oct 2008
    Tennessee
    Sold
    Oct 2008
    Tennessee
    Sold
